centre finder
Woodmagnet
23 Jan 2006
does anyone have a plan for making a centre finder,i remember seeing one ages ago but can't remember where.
cheers kevin :wink:
kevin what are you trying to find the centre of?? a tube, or straight wood.
a combination square will give you the quick and dirty answer on any smallish tube, since it will give you two 45degree lines.
otherwise, you need a straight piece which is attached to a piece across the top at 45degrees.
no drawing, but i would guess agoogle for centre finder would help
paul :wink:
Hi Kevin.
Here's a simple jig:-
You can make it any size you want, as long as the hole is exactly in the middle, between of the dowels.
I hope this is what you wanted.
i,m after something to find the centre of round wood for turning :wink:
