Squiggs
New member
Hi Guys,
First post and I'm after some help if I can please
I've been doing some relief work on my CNC machine in some Beech Wood. However I'm getting some fuzz on the wood even after running a finishing pass. What's the best way to clean up the fuzz without destroying the detail?
I've attached the photo. The fuzz in the ring is what I'm talking about, but that section is only 5mm across, so it's pretty small! I've used Beech before and never had an issue, I'm using new tool bits so they're sharp, so not sure whether the wood would be a factor. Seeing as I have a bit of this wood I thought I'd better get some skills in doing some manual clean up
I have tried the brass wheels in a dremel but they were a fail and sandpaper doesn't reach the little nooks and crannies!
