richardkirkman
Can someone give me a rundown of how to use a cabinet scraper properly and how to sharpen one correctly on a tormek.
lurker":3rrwlwcr said:Assume you mean the sheet of steel type rather than the record tool.
In which case I cannot se the tormek being a great deal of use
richardkirkman":3cuuwv7e said:Is a burr the same as a hook?
custard":3pn788x8 said:Yes, you could use a Tormek for that if you want a double bevel. Grind on the Tormek at say 40 degrees then hone at 45 degrees, polish the back and use a burnisher to develop a small hook. Personally I just grind and hone at the same 45 degree angle but each to their own, if you get the results you want then how you get there doesn't much matter. I use a the 80 scraping plane regularly, it's a fine tool.
David Charlesworth gives some good advice on scraping planes in one of his three books. If you're even moderately serious about woodworking you should get all three of them!
Good luck!
MusicMan":3j2j2oe1 said:We were cheap at my school. We were taught to burnish/hook the edge with the side of a screwdriver, and I still do.
