Quantcast
Cabinet carcass glue up
Neocleous
23 Jul 2019
Warrington
Hi everyone,
I need to glue up some carcasses and I’m wondering how other people do it.
The panels are 19mm veneered mdf boards and domino slots have been cut into the panels. The back is 19mm thick and cut to fit over the panels.
The sides of the panels won’t be seen so screws are fine to hold everything together while the glue dries. Just wondering how you guys would tackle this.
If screws are the way to go what screws would you recommend for MDF?
Mrs C
3 Jan 2016
United kingdom
screwtite from screwfix
Assemble the whole lot in clamps and get square
Predrill the holes, countersink and put a pilot hole in.
When you are drilling the ends of mdf it is still prone to splitting so I put a clamp over first.
Go through a dry run practice session
Be brave and glue.
Re the back, I would use 6mm for the benefit of weight and cost. I rebate the sides put the back on (no glue) and screw all the way round with no 3 screws.
decas
7 Jan 2012
Worcestershire
If you are using dominoes then I am not sure why you need screws as well. Dominoes should be fine on their own provided you pull everything up tight with your clamps.
Dave
Neocleous
23 Jul 2019
Warrington
Dave
It's not strength that I'm worried about, It's more how to glue and assemble everything and keeping it all square, my thinking was that screws effectively act as clamps pulling everything tight and I can move onto another carcass.
decas
7 Jan 2012
Worcestershire
Understood. To work quickly with a limited number of clamps screws make sense. I work slow these days and with Titebond the clamps can come off after 30 minutes.
Can’t really add to Mrs C’s advice. Do a trial run then just do it. If you are using Titebond then make sure everything is warm enough. Good luck.
Dave
Farm Labourer
20 Aug 2019
Norfolk
If you use Mrs C's method and the back is square and a good fit, then as it's rebated into the carcass, it will help everything stay square when clamping. If the sides fit insde the top and bottom you won't need long sash cramps either.
