Steve Maskery":1l3chazh said:
Can someone more knowledgeable than I am please explain how machinery is braked? Apart from my spindle moulder, which I can't fathom, all my machines are too old to be braked. How does a tablesaw stop inside 10 seconds? Or a bandsaw? Is it an electric brake on the motor or a mechanical brake on the blade (or wheel)?
Hi Steve
There are four main types of brake in use on "standard" woodworking machinery:
1. Hand- or foot-operated mechanical brake with brake linings. Very similar to the handbrake on a car and generally found only on narrow bandsaws and spindle moulders, although some Wadkin routers (the F-head ones) have a mechanism in their heads as well as some single-end tenoners
2. Automatic mechanical brake. Similar to (1.) above but the brake is pulled on under spring pressure and held-off when the electrical supply is on and the E-Stop or safety release is not active. Found on machines such as the Altendorf panel saw
The above methods require the brake, cable and linings to be inspected periodically and be adjusted (pain!)
3. DC injection brake. In these systems a device is fitted together with switch gear which means that when the E-Stop is hit the power to the motor os cut (it is a "self-holding" solenoid circuit) and DC current is fed into the windings which destroys the magnetic fields and causes the motor to "freeze" fairly quickly as the rotor and stator try to align (having now got dissimilar polarity). There are various combinations of this system and mechanical brakes as well as systems which monitor motor rotation and cut the DC injection once the motor has stopped turning.
4. Belt/pulley friction (a cheat). Some manufacturers (including MiniMax on some of their saws) depend on the fact that there is so much belt/pulley friction in their drive trains that the motor/cutterblock combination will halt within the required 10 seconds without the addition of a brake. With these you need to keep the belt tension high - just don't expect the belts or bearings to have a long happy life.....
I'm no electronics engineer, but those "crude approximations" are how I for one understand motor braking to work for the majority of woodworking machinery.
As to legality, well you know where to look..... A lot of the hand/foot mechanical brakes are no longer acceptable in law for training/commercial installations the exceptions being spindle moulders and (with an appropriate safety assessment) small band saws and single-head pin routers - and even that may be subject to HSE intrepretation inthe event of an accident.
Scrit
