StevieB
A few weeks ago I had some solid wood beech worktops delivered for the new kitchen. Halfway through cutting them my router blew up and I have only just got a replacement. Finishing off the cutting today on a corner cabinet I noticed that the smallest piece, 60cm deep by 30cm wide has bowed by about 2mm in the centre. This means the joint will not go together cleanly :evil: Its bowed so its high in the centre parallel to the staves ie from left to right along the 30cm axis.
Anyone any suggestions on the best fix? I can try weighting it in the centre and try to bow it back, I can try forcing it into alignment with biscuits and bolts but somehow I dont think this will hold flat, or I can align as is then sand/scrape the bow back down to level, although this will be an awful lot of work. I don't want to force it and risk snapping the piece as I do not have any spare. All ideas gratefully received as I am at a loss as to the best approach on this one!
Cheers,
Steve.
Cheers,
Steve.
