Richard T
I have an old (1930s) copper boiler that has popped its soldered joint around the pipe that comes out of the bottom and goes to the tap.
The bottom is domed and around three inches from where the wall starts there is a flange into which the pipe is (was) soldered. It's quite grotty as this is in the area that the gas flame has done a lot of sooting up over the years and it is impossible to get the pipe out of the flange to clean it properly. I've cleaned it as best I can in situ. and fluxed it - I suppose the best I can hope for is that the solder already in the joint will spread and mingle with new solder to close the gap.
Also I am concerned that my blow lamp won't be up to it - a bog standard butane canister job - quite good for standard stuff but maybe not up to heating a joint this big ... any idea of the sort of torch I should be thinking of?
This is all academic for now however as I still have to get the gas ring off (seized nuts) before I can get to it properly.
