Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 59
... well this particular dummy.
I'm struggling with an ill-chosen purchase - some slabs of purpleheart. Originally I had designs on a bandsawn box for the Domestic Controller, which mutated into a heart-shaped design with a lid for earrings, etc. Looked do-able on paper, but then the 'fun' started.
I'm not really having fun.
In order to achieve what I wanted, shapewise, I intended to bandsaw a heart'shaped body and lid from the fairly rough stock, before sculpting the exterior shape and making recesses for the contents. In order to do that, I've been trying to flatten four faces, about 200mmx200mm.
In 'full' sizes I've only got bevel-up planes - 4, 4 1/2, 5, 5 1/2 and 7. I'm getting best results with my 4 1/2, with a bog-standard Stanley blade, although I have a Japanese laminated one I've yet to try.
"Best results" gives the wrong impression though: the edges last around 10 minutes and tear-out is extreme and horrible. Part of the problem, I think, is that the grain, such as it is, is pretty much parallel to the surface.
Anyway, I've been grinding to 25, honing to around 40 (scary sharp to 2500 grit - I can shave with the results - they're not bunt). The frogs are all Common Pitch (45). I don't think it's steep enough, so a micro-back-bevel is called for.
The question is, given I can't change my planes to BU, what should I be going for on the angles, mainly to avoid the tearout, and does anyone have any tips, apart from keep the sharpening table nearby, to save the legs?
Cheers, E.
PS: Haven't been around here for a while - good to hear DC's getting better!
Cheers, E.
