Unboxed it last night, and it looks like a reasonable machine for the price. I didn't get a chance to adjust the tables, but it looks like it might not be too bad. I've certainly seen worse.
A few first impressions - Part No. DK2096
reasonably smooth table movement - table movement is just one gear meeting another, but it doesn't feel bad. I don't think they fitted enough gib screws for the tables (default seems to be 2), but I've not adjusted them yet so it might be just fine. The ways are smoother then I'd expected, considering the price.
Colour isn't bad - kinda looks like Delta grey.
they used crappy paint - flakes around the edges were coming off even before I took it out of the box.
strange choice in movement wheels - the forward/back wheel is just a large knurled knob, and the side-to-side one uses a removable handle. I'd have preferred to see normal wheels with rotating handles, but I guess they thought the unit would be too compact for them. If I find it too annoying I can just fit my own wheels to them.
Slightly damaged in transit - nothing serious this time, just a bent bolt which I can find a replacement for. Better then some other things I've ordered from Rutlands at any rate.
I put it together last night, but I didn't get a chance to put any real time into it. I tried to install the riser block, but was having issues with the fit of it so I just left it off until I can take a closer look. I will say that it appears that the riser block is going to limit backwards movement of the table though. Once I've got it all together and tweaked properly, I'll take a good look at the riser and see what impact installing it will have.
Axminster has a 13/16" to 3/4" chisel adapter, which will give me a little more leeway on what chisels I can use. I plan to order some N/H Mortice chisels and bits (Japanese) and put this thing through its paces over the next week or so.
Once I've adjusted the machine and fired it up I'll post an update to this. I'll probably wait until I get the new chisels though, since cheap chisels tend to make you want to throw things out of windows.
dak.
