exigetastic
I have just had a crack at this.... result was less than favourable (which may come as little suprise to most of you)
Basically I want to turn fence posts into newel posts in situ on my deck.
The plan is to bead the corners and run a couple of V grooves in the faces of the posts.
I have done a tester on the least obvious one. Basically I took a belt sander to the post, and this resulted in a much better look than the rough sawn fence post, however not suprisingly (in hindsight) the wood isn't exactly kiln dried So the router hasn't exactly faired well even with a small beading bit. The bit was brand new btw.
What advice could you guys give?
a) Don't bother it will never work
b) Wait for summer and (hopefully) a few weeks of dry hot weather.
c) Use a different technique (which I am unaware of)
Si
Si
