You will find that when you produce some there is no such thing, the ones I make and are currently working on vary in bore diameter between 65 and 90mm, best bet is to get intended recipient to go try some on in accessories store and check the diameter or make yourself a set of sizing rings for people to try on.wabbitpoo":d93z2178 said:Anyone know a typical set of dimensions for a ladies' bangle? I am sure there was an article in the mag a while back but I can't find it. TIA
wabbitpoo":1oe3wuqt said:Anyone know a typical set of dimensions for a ladies' bangle? I am sure there was an article in the mag a while back but I can't find it. TIA
petercharlesfagg (UK)":1nk9cd6s said:I made several and kept the internal diameter to 70 cm. which appeared to meet the requirements of most of the ladies.
Regards, Peter.
wabbitpoo":2hkphrlx said:petercharlesfagg (UK)":2hkphrlx said:I made several and kept the internal diameter to 70 cm. which appeared to meet the requirements of most of the ladies.
Regards, Peter.
Either you know some large ladies, or you meant 70mm.... :shock:
greybeard":2uli3ljn said:There will of course always be exceptions to prove rules!
