Dalboy
As some may be aware that Axminster gave away 20 bandsaw blades for members here to try.
Any way fitted mine yesterday and got it all running true.
The blade I have is a 13mm X 6-10tpi bi-metal M42
Being a new blade it cut through the wood with ease. I found it left quite a clean cut through two logs of 5" diameter and also a short piece of dried oak again at 5".
I have taken a couple of pictures hopefully showing the cut and the selection of wood I cut except the oak(this is after cutting the logs up). The small square section wood on the right is 1" square. Also the thin piece was a 1/16" slice of of the chestnut. How the blade will preform after a little more work can only be answered with a bit more time.
So first impressions are good
