axi saw ts200
pip1954
19 Aug 2011
lincolnshire
hi bought this saw a little while ago all seems fine but when i set the angle it seems stiff should i lubricate the threads and if yes how should i do it, ie what with (hammer) ,
pip
pip
This is possibly an unnecessary question, but... have you released the bristol lever to the top left of the depth wheel before trying to adjust the angle?
pip1954":32mtdyt6 said:
yes ,but you never know :shock:
any one got an answer #-o
My best suggestion is just to turn the thing upside-down and check that there's no gunk in the gears, and if there's anything obviously wrong. I'd probably use white grease for lubrication, but that doesn't mean it's necessarily a good idea! ;-)
It's worth mentioning that - while I wouldn't say mine is malfunctioning - my angle adjustment has been less easy than the height adjustment since new. I think it's as much down to the differing mechanisms used as anything. You may find that there's nothing more you can do about it.
