devonwoody
A couple of years ago a neighbour let me have some of their ash logs and I stored them in my workshop.
They came from these trees which have since regrown, (they were coppiced)
Marcross lent me his moisture meter over the winter and back in November 12
they were around 15%. So I cut one of the logs on the bandsaw (not vey well, I did not get straight even cuts, I could not control the log going past the blade)
Yesterday I took the thinnest slab and because I could not get a straight edge over the length I cut it to short lengths which I thought I might be able to make usable.
I put the shortest length to the planer and I did not like the operation, the wood surface was to uneven, so I had to make a surface suitable with the jack plane first.
after using the jack plane to get the planer going nicely everything then started to go smoothly, put through the thicknessor as well and got these pieces.
Managed the four pieces and was left with small waste pieces from the first slice.
I stacked them for the time being and might bring in doors for a week or two. guess I what I am going to use them for?
