Different Displays
New member
I'm new to the forum and turning, but not to woodworking...
The reason for this post is that I have been given an old lathe (hence the post title)- a Clarke CWL12 to be exact. It has been sitting in parts in a workshop for a while so is need of a good clean and sort out.
I'm looking for some advice as to what issues and problems I should be on the look out for.
So far:-
1) I've found and downloaded a manual for it,
2) The motor runs fine and all the pulleys look to be sound and square, and rotate freely
3) The belt is a bit worn but has developed a 'set' on it, so I reckon a new one would be wise.
4) Electrically it is sound, wiring is in good nick and nothing loose. It has been fitted with an NVR switch at some point.
Anything else I should think about/ check/ do?
I'm wondering if I should do the old bike trick of getting the bearings out (if I can) and giving them a good soak in warm oil (if they're not sealed of course)
Your thoughts, advice and observations would be welcome.
So far:-
