Peter G Denmark
I have been unable to find any guidelines to the tolerances of runout on arbors and table saw blades.
My arbor has a runout of about 8/100 of a mm (roughly 3/1000 of an inch) on the edge of the flange (diameter 75mm), which would translate to about 4-6 times that on the tips of a 10" blade. Almost 0,5 mm of wobble on that blade tips is entirely too much, so i will spend a day with a felt pen, a diamond stone and dial calipers knocking down the high areas.
But what is a reasonable target to go for, when it comes to blade wobble. I guess you can't eleminate it all together, but what is the point where it's "good enough". How much arbor run out do you have on your saws?
The bearings are ok (runs really quiet, and the deflection when trying to move the arbor up/down, side to side is around 1/100 of a mm, when assertng some force, which i think is within reason. Meaning - if i bolted a 20mm solid steel rod to a solid suface, i would be able to deflect that by 1/100 of a mm, so i don't think the bearings could do a better job.
I've spent 2 years restoring this (lemon of a) Wadkin saw, so i'm just about out of patience, and just wan't to build some beautiful furniture, instead of grinding, welding and straightening metal
