Mark A
Hi chaps,
We have two keys for our 2013 Vivaro. The tip of one key snapped off inside the ignition switch, and though the van could still be driven using the remainder of the broken key the other whole key could not be fully inserted.
To find out whether the problem was covered under warranty we had to pay £60 to the dealer. They said it was outside of the warranty, and the only solution was to replace the entire barrel for £307.
We found an independent mobile locksmith to fish out the broken piece of key, cut a new one and reprogramme it to work with the central locking for £80. I don't know if that was a good price or not, but it was a lot less than what Vauxhall wanted.
The broken tip of the key has a hole right through the middle, which the locksmith believed was a weak point which lead to the key snapping.
There's obviously a design issue with the key
Has anyone had the same problem, or even just heard of it happening?
If so, did you approach the van's manufacturer?
Any advice would be much appreciated!
Mark
P.S. Here's a pic from Google of the key.
Mark
