I'm making some items which require a series of very small holes drilling. More precisely around 80 holes 1.7mm size in a 1 metre length of ash using a drill press.
I've done a few of these in the past with only the odd problem but yesterday I had four drill bits snap in drilling 3 lengths. Two I managed to extract the broken bit and recover but one snapped deep inside the hole so it's junk.
I'm plunging 4 or 5 times for each hole to try and ensure the bit doesn't clog and the hole is clear and I'm taking my time over each hole so as not to push too hard. Is there anything else I can do to prevent the bit breaking?
I have just ordered 100 new bits with the plan to use a new bit every 30 holes or so, will that help?
Any advice would be gratefully received
Phil
Phil
