marcros":2kqtfzf5 said:are they not run on the spindle moulder?
Oh.......ColeyS1":21khgwdx said:You've got a tilting arbour, also a tilting variable cutter block. A planer thicknesser can put a 9 degree angle on a cill, you'll just need to stick a bit on after to form a rebate
OK,my brain is starting to get scrambled will have a cup of tea, back online later.ColeyS1":1zj1347x said:An 80mm block will do your 9 degree cut. Once you start using your machine you'll have a better understanding of how it works. Just for fun, cut out a bit of wood the same size as the 80mm block, drill a hole in it and set it up on the spindle to see if it's suitable.
Coley
I get on the lathe and turn an 125mm x 80mm cylinder and drill a 30mm hole in it. Then using some planed scrap make up a rebated cill section using the tablesaw. Will put on spindle moulder and see if any lights come on. Will also try the other methods people have suggested and see how I get on, if acceptable results saves buying the 80mm block.ColeyS1":3jzpe0ml said:An 80mm block will do your 9 degree cut. Once you start using your machine you'll have a better understanding of how it works. Just for fun, cut out a bit of wood the same size as the 80mm block, drill a hole in it and set it up on the spindle to see if it's suitable.
Coley
