My friend bought one of these a couple of years ago.
First thing he did was broke the faceplate - which seems to be constructed from something akin to Kendal Mint Cake.
Second thing he did was broke the replacement faceplate they sent him.
Every thing he turned was catching and flying apart.
Long story short, he really wanted to pursue the hobby so shelved the ALDI lathe and bought a nice one.
He's given me the ALDI lathe to repurpose into a buffing station.
Here's the 'fun' part...
The spindle had 3mm end-to-end play in it. Solved by stripping it down and putting a simple washer against the poorly machined part of the shaft where the bearing fitted.
The bearings ... Well, they say the Atacama Desert is the driest place on Earth. I beg to differ. Eased the seals from the bearing, blew out the dust and packed them with grease.
The pulleys were about 1/2'' out of line, so kudos to whoever makes the belt, it was still in one piece.
Putting the whole thing back together was fun too.
Note: Always be wary of something that is manufactured by 27 people that never met. Now I realise why every hole was slotted.
It now runs true (well, truer) and quiet (ish). Should be fine for a buffer if I can get a M18 x 2.5mm fitting for it.
So, the moral... If you want to get into woodturning, DO NOT buy this Workzone lathe from ALDI. You will very likely end up in A&E with pieces of Kendal Mint Cake Faceplate sticking out of your face.
