PeteG
I've nearly finished, just need to drill holes in the alloy rails before attaching to the fence, but I'm a little stuck on the best way of attaching the wings/side tables to the base. At some point I'll be using a sacrificial fence for the odd job so I've decided to make the side tables slide backwards and forwards so to speak and this is where
I could do with a little help?
Should I router grooves in the base with a bolt coming up through the side tables?
Should I router a slot in the side tables with a bolt fixed in the base?
Or should I put 1/2 inch T Track in the base?
