Advice please
JimiJimi
7 Jan 2013
Hebden Bridge
Hi all
I want to attempt to cut my first portrait. I have looked online and am curious how people make the black backboard to glue it to. Is it something that is purchased and is already black? Is it a piece of paper sandwiched between the two? Is it wood that is painted on?
Jimi
I made this burn on A4 sheet of ply and mounted it in an A4 Certificate frame (£1 from Poundworld)
I got a selection of various coloured A4 paper/cardboard sheets for another shop (can't remember which, maybe the local knitting shop) and this is the result. Getting a supply of coloured paper is great as you can change it to suit.
    82.2 KB
hi which portrait are you thinking of doing ???, I jumped in at the deep end and went above my capability's but soldiered on and got better . I use 2 sheets of A 4 / 3 mm plywood and paint the back one black where it can be seen, if you do use coloured paints it would cost a fortune, it also helps this way if you want to put a hanger on the back , again I use saw tooth hangers and superglue them on . hope this helps
john
pain is the best attention getter
