Advice Needed - Batch Cutting 4mm Brass Rod
anaminal
6 Dec 2012
Leeds
Hi All,
I need to batch cut lots of 4mm brass rod into 27mm lengths (around 200 needed). I started this with a hand saw but the accuracy suffers after a while so would like to find a faster method.
I have no powered metal cutting tools, but a well equipped wood workshop. I could buy something if it was cheap (I've seena wood scroll-saw on gumtree for £50). what would be good for this? Any advice?
Many thanks in advance,
Chris
A mitre saw with a TCT blade and a length stop? Stay out of the firing line though!
How accurate do you need the 27mm length?
Cut a mm or so over length on Bandsaw or in mitre block with fine hand saw against stop.
Place in closed end dimensioned tube, Ideally steel but even a hardwood should work for that quantity.
File off ends to length. flush with tube.
    2.7 KB
Could you not find a local fabrication shop to do it for you, multi cuts like this were nipper jobs when I was in full time fabrication and on brass you don't need a TCT blade just a fine tooth HSS one and a good drop cut off saw and stop. Shouldn't take half an hour for 200
all great suggestions - thanks!
They are to be used as rivets (both functional and decorative) so the ends will be hammered flat, but yeah they need to be precise to ensure consistency.
After sleeping on it, it did occur to me that I'm using a cheap as chips hacksaw for my cuts - an upgrade might help! And yeah a mitre block and depth stop is a good shout. Like the idea of the tube for filing down CHJ - thanks.
I read that I shouldn't attempt this on my wood bandsaw as the waste will damage my wheels (Kity 613).
If I could find a fabricator to do the work for me I'd be very happy to pay for it. Where do you find these places? I'm in Leeds but wouldn't know where to begin looking!
Chris
cheap diamond blade tile cutter, get a block of wood drill a hole in the end to the depth you want the length of rod, put the rod in and use the wood as a guide and slice the rod to length,
Chris
If you have time it would be worth spending 5 mins googling local engineering companies, if there are any small ones very local then you will get more joy by going in and asking them. My local engineer charges £40+vat for bit he does for us, so might give you an idea of cost.
Thanks again all - legends the lot of you!
Snips and sand down is a good shout. I have bolt cutters but they were far too inaccurate - snips might get me a lot closer!
Idea of binding together a load and doing multiple cuts and multiple sanding is a winner I think!
I'll have a look for local engineering companies and see what they charge. And somehow can't believe there are companies that specialise in rivets! Never even though to look for that! Ill give them a shout and see what the cost is.
Many thanks all,
Chris
small peasants or small castle. lol
Deaths letter opener?
when I do a set of knife scales I use my mini croppers and buzz them over the belt sander, takes me a few minutes but I'm only making 3-4 at a time.
haha indeed - a 16th century Japanese castle perhaps (they're used in martial arts :) )
I'm always up for a bit of experimentation on the cheap - and as my workshop is full to the gills already a space efficient and low cost solution sounds good to me! I'll do some experimentation...
Chris
