DavidE
Hi there,
Sorry if this is a daft question - I just wanted a quick sanity check of my understanding of adjusting the Tandem slides... The manual I downloaded is helpful, however, I did find a few things ambiguous and clarified my understanding by fiddling (as with most things).
Having fiddled around a bit I've come to the conclusion there are two adjustments. -
The front adjustment - I thought this initially did the position of the drawer front in the plane looking into the drawer. I soon realised this adjusted the height of the drawer front.
The back adjustment varies the tilt of the drawer - I'd picked this up from the manual and it is pretty clear when you start moving them what they do.
I can't find anything that will adjust:
1) The fit of the drawer at the front in terms of fitting flush to the surrounding edges?
2) Or the lateral position of the drawer to centralise it?
To adjust the above I figure I have to move the slide where it is fastened to the side? The later I guess could be adjusted with a bit of packing, or I think I might be able to sort that by moving the side, as the thing I am trying to adjust is a table.
Please let me know if this isn't clear I will add a diagram. I’m only trying to adjust in both directions by about 1mm as it is just slightly out on one side – the other side is spot on.
David
David
