Anyone make their own taper drills?
Rorschach
Guest
6 Jan 2016
Devon
I ha cheap set of drill/countersink bits. The countersinks work well but the tapered drills are very poor. I have used trend taper drills in the past and they are very good, much more like a conventional drill bit. I was wondering if anyone had ground their own taper drill bits and if there are places to work out what kind of taper I would need to make?
I'd have thought they would be very difficult to make properly as in a normal drill the sides do not have any cutting action. In a taper drill the sides will need to be sharpened to cut the wood.
-Neil
Calling your drill bits "snappy" can't be a good move.
What's poor about the drills themselves? Could a quick sharpen maybe be enough to improve them?
Are you using old style screws, probably slotted? Modern screws are generally parallel on the threaded part with a shank that's narrower rather than wider, so the requirement for tapered drills is probably disappearing.
graduate_owner":1aq9niuu said:
Maybe a dumb question but - why would you want to drill a tapered hole?
K
Usually for old style cut thread brass screws, which are tapered.
