mickthetree
Following on from Colarris's thread about cleaning up dovetails, I cut some myself at the weekend and they needed a fair bit of cleaning up.
Happy with my marking out, but I struggle with cutting a straight line.
I try to let the saw do the work, try to relax, try to make sure my arm is at 90 degrees to the work, but I still struggle.
I've tried pull saws and at the minute I'm using a nice little crown gents saw.
With the board vertical in the vice I start the cut dead straight, then make my way down the vertical line. The line nearest me is fine, but on the opposite side of the board, the saw dives off to the right every time. I try to adjust but nothing seems to work.
I'll have another go tonight with a pull saw and see if I can describe whats occurring there.
They end up looking ok once paired to fit, but I spend 5 times as long cleaning up as I do marking and chopping out.
Cheers!!
Cheers!!
