• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Sold Workshop Downsizing - Felder Combination Machine
Yojevol
Clocking on
29 Jan 2017
Cheltenham
I purchased this machine new in 2005 having cut my teeth on an older s/h version for the pervious 6 years.
It features a 410m wide PT, spindle moulder with tilt & reverse, 310mm saw and long sliding table with removable panel saw fence.
It's basically a 415V 3ph machine with a built-in inverter for 240V 1ph input. This enables speed control on the spindle moulder.
A 415v power socket has been fitted and is controlled by a selector switch which diverts power from the SM so is frequency controllable.
There are a few Felder extras:-
Table extension
Hold down
Short saw fence
High speed router cutter shaft
In addition there are 3 saw blades and SM tooling. New owner will need to buy new planer blades.
The machine is basically a saw/SM bolted to a PT. These 2 could be separated for ease of transport and could even be used as separate machines although they would need to be connected by power and control cables.
All yours for £7000
Get in touch if interested, Viewing welcome. Transport can be arranged with a local company.
Brian
