What else can be done with caliper
Niki
18 May 2006
Poland
Good day
Yesterday, I've seen a digital caliper for 25 Zloty that are - according to yesterday's exchange rate - £5½ and I could not hold myself...(yes, I know that I have 4 dial calipers but....you know... :) )
I liked very much the possibility to "Zero" it at any distance and lock it.
And - as usual - every new tool that I buy, must go first through "modification" to improve it...and so I did.
I'm using the caliper for measuring wood thickness, width (up to 150mm), to set the table saw blade height, to set the fence / blade distance (again, up to 150mm), to set the router bit height and bit / fence distance on the router table and, to measure the depth (of mortise)...
I would like to ask you, what else can be done with caliper
niki
I have an axminster compound slide vice for my bench drill and have mounted 2 cheap digital verniers to it. Using the 'digital readouts' I can drill holes for scrapping out mortices or at precise pitches etc repeatedly and accurately. I can also use it for drilling at offsets by positioning the drill bit above the corner of a work piece and zeroing the calipers.
I have a 300 mm digital caliper and find I use that a lot as a simple marking gauge as it scratches wood easily and i don't have to check the setting :).
Thank you
Mark
I don't have band saw...yet...but you scared me, 15,000 PSI ??? it looks more dangerous than the table saw :)
Robert
I've never thought to mark with the aid of caliper...great idea.
Regards
niki
