Wadkin planer restoration almost complete.
Andy RV
14 Feb 2009
Uk
This is the old Wadkin planer that Karl kindly donated to me. I've completely stripped the whole thing down and cleaned everything, replaced the bearings and fitted a 2HP single phase motor.
I've also repainted with industrial enamel paint, just need to build a guard around the pulley and have another hand wheel cast for the table adjustments, but apart from that its running well.
This is how Karl received the planer, he'd mostly dismantled it and gave it a bit of a clean.
This is how it is now
And a big thanks to Karl for giving me the planer!
:shock:
Holy dung Andy - have you actually been to bed since you picked it up :lol:
Looks absolutely superb. Glad you had the time (and knowledge!) to do what I couldn't!
How does it perform?
Karl
Superb job, you could actually have a very good sideline refurbishing old Wadkins etc and converting to single phase. :D
remind me, what was the planing width? 6"?
What's that big cylinder behind the fence? Is that where the motor used to be?
I'd cover up that belt before something goes horridly wrong as you say, after all that, does it actually work well?
Aidan
Top Spindle\Pulley would be my guess.
Thanks everyone.
Yes I'll be making a cover for the belt drive very soon. It works very well, taking full width cuts without a problem in hardwood. The cutting width is 6 inches.
The cylinder behind the fence is the original motor case which is cast and is the mounting point for the fence, so it couldn't get rid of it, instead I've cut a slot to allow the belt to exit while retaining the fence mounting point.
Excellent clean up job.
If you have any spare time maybe you would like to give mine a clean?
...I see the extraction's working well, George!!! :D
Andy, outstanding restoration job! 8)
Sure! As long as I can keep it when I'm done! :wink:
Fine job Andy,
All set for the rest of your woodworking life then.
I like the guard... Way better then the one on my Sedgwick. Must see if I can fabricate one. Pop-rivets should do the trick! :lol:
Hope it gives you some great service, but agree with Bob. Watch that belt!
regards
:D
Andy - I showed SWMBO the before and after pics.
"How much did you sell it to him for?"
"Nowt - I got it for nothing, so I couldn't make a profit on it"
"You plonker!"
Women :lol:
Karl
