Turning Chisel Bevel Angles
Elapid
18 Apr 2012
Cornwall
Can someone please link or post the usual or optimal sharpening angle for common turning tools please?
I've had a google and a search on here but not found much.
Some help from the Help sticky above.
Skew chisel:
Front face 20 deg to a long edge, bevel flat width approx 1-1/4 to 1-1/2 the tool thickness.
Parting tool:-
Sloped face width approx 1-1/4 times the blade width.
Scrapers 70-80 degree front edge.
Try those for starters.
Hi
It is very much personal choice and experimentation. My spindle gouges are around 35 degrees with skews being a little longer. Bowl gouges are 65 degrees but these are a very contentious issue. I've had one professional turner tell me to my face that 65 degrees won't work and another tell me he uses an 85 degree regularly for some difficult cuts so take from that what you may.
Some years ago everything was 45 degrees and that was that but it is now recognised that most angles work, just some work better for some than others!
HTH and doesn't confuse further!
Richard
