The wonderful world of Niki's Jigs
Status
Not open for further replies.
wizer
3 Mar 2005
This was hidden within another jig thread but I thought it deserved updating and it's own dedicated thread. This means that it can be found easier and I can update it easier.
If any links are broken or pics are missing, please post in this thread.
Different way of cutting 45* frame
Cross-cut sled, different way to make it.
Shop vac modifications
Drill Stand modification
Drill press table improvement
Screw cramps
Sanding blocks
Hold down clamps
For amateurs only
Cheap "Grip-it" clamp repair and improvement
Saw blade and router bit height guage
Cutting dado with hand router
Hand router bit height setting aid
Caliper (micrometer) modification
Another Shop-vac
Clean paint tray
Wild router table
Foam brushes
Doweling with router table
Drilling shelf support holes
Magnifying glasses
Panel glue-up aids
Jointing with router
Doweling jig part 1
Doweling jig part 2
Feather roller for table saw
Push blocks
Feather roller - version II, prototype.
Straight edge on table saw
Feather roller, final version
TS fence memory
Dust free sanding
Amateur's working methods
Hold down roller for TS
Panel glue-up, overcoming cupping boards problem
Cutting strips on TS
CS cutting table
Saw blade cleaning with STP
ROS DC improvement
Router table fence distance and stops setting
CS (or router) Offset plate
CS with Zero clearance insert, why it's chipping?
T square
Measuring tape, not only for measuring
Measuring tape - version II
Construction Square - checking & adjusting to 90*
Blade cleaner
Triangles
Jointing with hand router II
Checking Diagonals
Checking Diagonals, version II
Checking Diagonals, version III
Checking diagonal, Version IV
Logs or round wood cutting jig
Router Lift for amateurs
Glue line on router table
Triangles
Amatorski Patentski
Sanding Paper everywhere
Screw clamps - long jaws
Drilling small hole over large hole or vice-versa
Even bigger triangle - "Copy" and "Past"
Tenoning jig for table saw - it's rolling...
Sharpening
New router - New table
All seasons crosscut sled for TS
Router table T-fence
Router table fence setting
Lo-tech TS blade alignment
Caliper modification
My first box (finger) joint
Rolling Mortise jig for router table
Router Lift
Rolling Mortise Jig - The test
Hold-down clamps for...everything (LARGE PHOTOS)
Cutting very small pieces on table saw
Do you have a Saw board (AKA - circular saw guide)
Crosscut Sled - my way
Knobs - easy, fast and cheap
Drill Press - holding wheels (knobs) and small parts
Fence stops (yes yes, easy, fast and cheap)
Circular Saw Guide
Shop-vac "filter"...always clean...
Thin boards glue-up
push block
Folding adjustable height table
Cutting 2 mm strips on table saw
Hold-down clamps - simple, fast and cheap...
Well done Niki!
Wow, I didnt know there were so many. Thats a real contribution to this site.
Many thanks Niki :shock:
WiZer,
Well done.
I have been bookmarking all of Niki's jigs for future reference.
Surely, now is the time for a mod/charley to gather up all of these and post them into the How-To section under jigs. It already exists and has a paltrey 2 entries.
How do we make this happen.
regards
alan
I would buy a book with all these in - it is relatively easy to self publish a book - I made a one-off for my wife, of photos and words about us, a one-off in 10" x 8" was about £30*. If Niki was to take orders, a limited edition run wouldn't cost a great deal per copy, even coming from USA - I used
http://www.blurb.com/create/book/info?c ... Qgodr1qw1Q
but there may be european sites of a similar nature.
* - you can get huge brownie points here, chaps........
Thanks WiZeR, bookmarked
and a big thanks to niki. your posts are always an interesting and full off great ideas. pete
Many thanks for collating all these jigs, I have bookmarked the page.
Bob
Top notch WiZer, this one goes to the top of my favourites file, many thanks.
regards, Rich.
No problems guys.
Niki can you post a link to any new stuff in here when you post it.
WOW WISeR
Thank you so much for your effort....I also bookmarked this thread....
As for now, all my woodworking is "frozen" because of the Polish winter but from the spring, maybe I'll have some new jigs.
On some of the threads, there are no pictures because it's old or I made better one or just because of safety reasons but, as I remember, I gave a link to the other thread.
WISeR, I think that it will be better, if I'll send you a PM and you will "Edit" your list.
Oh, by the way, the first post on the list, "Different way of cutting 45° frame" is the one that gave me the "Top Tipster"....
Thank you
niki
that's fine Niki, if you PM me with a list of correction and i'll make the changes in the OP.
Good work Wizer, it must have taken you a couple of hours to sort this lot out.
Also good work from Niki.
Bookmarked for future reference.
NickWelford":25c70ulh said:
I would buy a book with all these in - .
I said the same thing about six months ago, Niki replied that he really wasn't that interested in making money out of all his ideas. He did get an article in one of the American mags, he told them he didn't want paying, but they e-mailed him back that he had to accept payment, something to do with their standard contract.
As mentioned above it really would be good if Charley could get all these in one place 'cos they are so useful. I know, I've made a couple and will likely be making a few more in the comming months.
He has contributed a lot to this forum and we should be thankful for his ideas.
Thank you Losos
You are correct about the payment....it was about the "miters cutting jig"....there was something in the contract that said that I cannot publish it for 6 months and I thought that I shall have to remove all the pictures from any forum that I posted it, so I told them "you can have it free and you have my permission to publish it in your magazine"....
But than, they explained that it's ok to post it on forums, I only cannot give permission to any other magazine or e-zine to publish it so, I signed the contract.
niki
It's annoying when the pictures disappear from old posts, and I didn't want to loose all of Niki's wonderful jigs the next time a photo site goes out of business, so a couple of nights ago, I pointed a web crawler at this page, and compiled the results into one massive PDF file (complete with an index).
It's 67MB and a whopping 1202 pages long, so don't expect it to download too quickly.
http://yourhome.org.uk/The_Wonderful_Wo ... s_Jigs.pdf
beech1948":59pecxvj said:
WiZer,
Well done.
regards
alan
Only Charley can do this - drop him a pm
Well done Niki!
Posts With missing pics or superced are:
Blade cleaner
Checking Diagonals
Clean paint tray
Doweling jig part 1
Doweling jig part 2
Panel glue-up aids
Push blocks
Sharpening
Waka":3p2yhbee said:
In the mean time could it not be made a sticky?
I certainly think the forum could do with a section with some form of access rights allocation to allow moderators or other appointed persons to add content like this, there is so much useful reference material that could be collated but I think it is unreasonable to expect Charlie to keep up with it all via Forum Front End software changes which are required at the moment.
The problem of disappearing pictures is always a problem, a couple have disappeared from Tom's Boxeslist in the last week.
Status
