Les Mahon
Hi,
don't know if anyone has this lathe, but I tried setting mine up over the weekend, and ran into a couple of problems - any help greatfully recieved!
1) The leg stand I got with it had been taken off the shop model as there was none in stock, and all I got were the 4 tubelar legs - I am assuming that I need some sort of bracket to attach these legs to the lathe as I can see no other way?
2) the nuts on bothe the headstock and tailstock have a type of split pin arrangement next to the bolthole, which I can only assume is to stop the nut spinning when turining the handle - however, the split pin is far too close to the bolt hole to allow the nut to thread on to the bolt. I can get it to work by taking out the pin - but you need to use a spanner to adjust which is a pain.
If this is not clear I could post a photo
Les
Les
