reclaimed woods, metal finders / detectors?
Higon
30 Jun 2014
Milton Keynes
I'm thinking of using some reclaimed wood but I'm not sure how to check that it is clear of old nails and other rubbish. Any suggestions on something to find the nasties?
I seem to recall that 'Norm' uses a wand type gizmo but can't find the correct search term for it...
a decent stiff brush would also be a good idea, to get rid of any surface grit.The other trick that i have seen recommended is to use a belt sander before putting it through any machines, so if you have missed anything it only damages a sanding belt rather than dinking a blade. It will also give you a cleaner view of what may have been hidden in grubbyness.
Thats a very good couple of ideas there! thanks for that.
If you can find one for hire, Makita do (or did) a very effective rotary brush, a bit like a handheld version of those road sweepers they sometimes use to clear mud after roadworks. With a steel bristle brush, it shifts an awful lot of crud for relatively little effort and doesn't dig in like a wire brush in an angle grinder might.
If I still lived near MK, you could borrow mine, but a 1000 mile round trip to borrow it might not be economical :(
I have a similar thing i think, they used to sell them out of Screwfix.. but I haven't seen them in the recent catalog. ah here they are tool station, although the bristles are nylon, is this the sort of thing you mean?
http://www.toolstation.com/shop/Pow...asives/Nylon+Brush+Cup+75mm/d80/sd1920/p90287
The garrett and the other one look very nice but ouch to the cost! lol.
I pretty sure dickm is referring to this...
Streuth! that is a serious bit of gear! I thought I knew most of the power tools available but I've not seen that before... might as well use "new" wood at what it must cost! lol.
Thanks Wuffles, the Ebay item is a good find! more within my budget too! :)
Hi
I'd recommend you try to get more details before purchasing - the trouble with most cheap metal detectors is the size of target they will identify. Not sure that 'body scanner' would pick up a small nail - the Garrett will react to items smaller than a dress making pin - you get what you pay for.
Regards Mick
