I'm a hobbyist woodworker and have never used a shoulder plane. I have plans to make some replacement doors and windows, using M&T joints, so asked to be included on this passaround to assess whether I should add a shoulder plane to my armoury and, if so, would the Luban 92 fit the bill?
Unwrapped the package (come on, which of you previous users popped most of the bubble wrap
- an addiction of mine) and was struck by the plane's aesthetics - I like the black/steel contrast and it looked and felt well engineered. I shall say no more on that front as Glynne covered it comprehensively.
I believe softwood is generally harder to plane than hardwood so for a test I decided to cut a tenon, rabbet and dado in a well seasoned (i.e. dry) 4"x2". Usually, I'd cut the tenon with.....a tenon saw and then clean up the shoulders and cheeks with a chisel (and, on a bad day, with a turnip file). The rabbet and dado would normally see me break out the Record 405 but I do find it a bit of a faff to set-up. My criteria was to judge if the plane would be an improvement - in ease of use and/or accuracy.
In brief, the plane performed as I hoped and expected. Shaving the end grain on the tenon shoulders was straightforward. I was particularly impressed with the ease of loosening the blade (quarter turn on the knurled knob) so that I could skew it ever so slightly to one side in order to get right into the corners. Similarly, the blade could be advanced and retracted easily - I usually loosened the lever cap but found this wasn't essential.
The edges of the rabbet and dado were established by saw and the plane quickly and easily removed material. I fiddled around with depth of cut and found ease of use at both shallow and medium depth. This was all cross grain work.
On ergonomics I did struggle a bit, finding it difficult at first to establish a comfortable and effective handhold. This was not due to the already documented sharp edges (not really a problem for the amount of use I'd envisage) but more the absence of an obvious place to grip it. This probably reflects my inexperience, rather than a plane deficiency.. I eventually settled on the traditional grip (as Geoff demonstrated in his video) and also tried the 'japanese style' described by Matthew. I actually preferred the latter - it enabled me to keep the weight more evenly over the blade.
In summary, I'm convinced that a shoulder plane would aid my planned woodworking. Though the advantage over my chisel/file method for tenons was not great the versatility it would offer is a marked advantage. Would I buy this one? Well, whilst waiting for this to arrive I had bid on a Clifton 410 and 420 but both went for c.£125, compared to the c.£95 cost of this plane (Cliffies are c.£180 new). So, on value/performance grounds yes - with just a slight reservation as to whether a smaller version would better suit me. I need to try another before I can decide!
My thanks to Matthew for the opportunity to try this Luban 92 plane out.
Mike
P.S. fluffflinger/Richard - plane will be posted (recorded) to you tomorrow (Tuesday).
