Produce pocket holes in ONE-STEP with Armor Tool's Auto-Jig Pocket Hole System
Wood Workers Workshop
UKW Sponsor
16 Nov 2021
Threshing Barn, Upton-upon-Severn, Worcs WR8 0SN
ONE STEP and you're done!
Armor Tool's Auto-Jig Pocket Hole System offers unprecedented efficiency and convenience. Instead of five or six different steps like many other pocket hole systems you can produce pocket holes in ONE STEP.
FREE UK Delivery on all orders over £75.​
ONLY £159.95​
Self-adjusting features
Self-adjusting Drill Guide Block​
Insert your workpiece into the Auto-Jig and engage, the drill guide block will automatically self-adjust to the correct height and angle based on the thickness of your workpiece. That's it, you’re done!
Self-adjusting Drill Bit Collar​
Just like the Guide Block, the Drill Bit Collar will automatically adjust to the correct depth and simultaneously synchronise with the Guide Block. Just tighten with the onboard Allen Wrench and you’re ready to drill.
Auto-adjust Clamp Makes Set Up Easy​
The most efficient and versatile way to secure your workpiece. The Auto-Jig is equipped with our patented Auto-Adjust technology which allows you to clamp varying thicknesses without readjusting your clamp while maintaining consistent pressure. Clamp and GO!​
Colour-Coded Screw Guide​
To ensure accuracy, the Colour-Coat system matches the optimal screw length in relation to the thickness of the material and depth of the pocket hole. The Colour-Coat system also serves as an anti-corrosive coating. Perfect for indoor and outdoor activities.
