Milescraft pocket hole jig
Spectric
Moderator
Staff member
Moderator
19 Feb 2015
North Cumbria
Anyone seen this flyer from the WWW, if you are into pocket holes then this jig looks good and is made of metal !!
I use the old Kreg which is good and has done a lot of holes, this Milescraft jig has some nice features like adjustable spacing for the drilling guides which means unlike the Kreg where you have to move the workpiece in some cases with this you can just set the spacing and also it uses a split depth collar on the drill with hex headed grub which is better than a solid collar and slotted grub as on the Kreg and many other jigs.
