RobertMP
I'm building up to refreshing our kitchen with new doors and drawers. So far I've got competent enough with spraying my workshop cupboard doors and tested the painting I will need to do on the exposed faces of the current kitchen cabinet carcases and am now looking to try making a first MR MDF door.
I've been reading a lot about MDF kitchen doors here and went out today to buy one sheet of 18mm MRMDF and one 6mm for the simple (shaker?) panel....which is where the problems started. 18mm is easy to get hold of but 6mm does not seem to be kept in stock in moisture resistant.
So first question - if the frame is MR does the panel need to be MR too? I'm assuming the MR stuff takes edge finishing better which doesn't apply to the panel?
And while I'm here... Construction method. I was thinking of running off some 1220mm long strips 60mm wide out of the 18mm and running them through the router table to put a 6mm groove central on one edge. Cut to length and then forming a matching tongue on the ends of what will be the top and bottom of the door. Is there a recommended way of doing it? Oh and dust issues aside, if I felt like putting the cut edges through my planer thicknesser will it do any harm to the blades?
Thanks for any help.
