Harrygary
Hi. I was wondering what is the best way to put letters or pictures on to wood. Would it be Mod Podge or PVA glue? I want to print letters off and scroll saw them out for different projects. Many Thanks Gary (homer)
ChrisR":afr3hdoh said:Gary.
The reason for the masking tape first is for ease of removal from the wood surface after cutting out, Pritt straight to the wood, and it will take you as long to remove the pattern as it did to cut it out.
Chris R.
mac1012":xjp33uzy said:My method is the same as steves , I pritt stick mine straight on , sanding the pattern off with my makita palm sander takes about twenty seconds far less time than me putting masking tape on(and definatley less time than cutting the piece out) and as I sand my work to a smooth finish it makes sense to kill two birds with one stone , my wood I buy invariably has imperfections in them a mark here a dint there so I like to bring it up smooth ,the Makita palm sander is not brutal and is very good for 65 pound and accepts velcrove and plain sheets I prefer hermes velcrove perforated sheets from axminster and I have it hooked up to my record dust extractor if anyone knows of any suppliers that sells wood that is perfect and smooth ready for oiling then please let me know
also with items such as my reindeer that I am making a lot off I stick the pattern pieces down say enough for ten on the plywood board then rough cut around the parts then cut out each piece on the scroll saw , if I was using masking tape I would have to tape the whole board up first before I stuck all the patterns on the board it would take far too much time to do that and as sell my work and time is money it wouldn't work for me.The birch ply I use has a good veneer , plenty enough to take the pattern of quickly and get a nice smooth finish.
Now mount spray if you put too much on that is a pain in the ass to get rid off , prit stick extra strong no problem
mark
ChrisR" Have just taken delivery of £235.00 worth of Baltic Birch ply from (Woodstock said:It'd probably cost that much again to have it delivered to Yorkshire. :mrgreen:
benjimano":1r2t926k said:I use spray mount.
The Works sell large cans of Elmers for £3 iirc.
I found it to be of the same quality as 3M but for a fraction of the price.
Easy to remove/adjust.
martinka":1g35o4s2 said:benjimano":1g35o4s2 said:I use spray mount.
When I saw this mentioned a week or so back, I paid a visit to both local "The Works" outlets, and no Elmers to be seen.
scrimper":2glkjyqh said:martinka":2glkjyqh said:benjimano":2glkjyqh said:I use spray mount.
Same here!
