How to paint letters into wood?
bp122
Expert at Jibber-Jabber
20 Aug 2019
Haddenham
Hi all
I have gotten a couple of house number signs made by my mate who has a CNC.
One in walnut and the other in oak.
The walnut one is for me and I intend to use white letters. And a friend of mine who the oak one is for, wants black letters.
How do I go about this?
Do I need to apply a sealing lacquer first and then paint and apply a lacquer on top? Or do I paint directly and then finish with a lacquer?
Also, what paint and lacquer (make and model) is best for this?
Thank you.
B
Definitely seal first, otherwise the paint can bleed. However you need to be happy that you don’t have any major divots or holes, so possibly:
1) sand the top surface
2) seal with a thin, clear layer; e.g. spray-on acrylic.
3) paint by brush or spray
4) sand back
5) seal again in the same as step 2.
Ordinary gloss works fine, then once dry a gentle sand over the top gives you crisp lines. The only time I’ve had a problem is on cedar when the paint just wouldn’t harden, maybe that’s where sealing should have been done
