Doug71
I have been asked if I can make two handrail sweeps like these and about 600mm of straight handrail to go between them.
It doesn't need to match exactly, just something like and the builder says he can fit it himself.....
The straight middle bit is no trouble it's just the curvy bits![Face with tears of joy :joy: 😂](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f602.png)
I was thinking I could maybe do each sweep in two parts, make the bottom flat part and kind of make a double edged bullnose piece as a capping to sit on top? The small bullnose piece that runs along the bottom could be put underneath after in one full length?
The other way I thought is to stick 2 D shaped pieces on the sides after cutting everything to shape which would probably make it easier to machine?
The top of the new rail is okay with just two bevels on or a single large gentle round rather than the mould on the top of the pattern which will make it easier.
It's a long way away so I won't be seeing the original in the flesh, I just have an offcut of the original handrail and a couple of cardboard templates for the sweeps to work with.
I have a spindle moulder, router and plenty of cutters for both.
I think the builder doesn't realise how awkward it is (he thinks I can make anything).
Any thoughts?
Thanks, Doug
![handrail 2.jpg handrail 2.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/104/104290-handrail-2.jpg)
![handrail 3.jpg handrail 3.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/104/104291-handrail-3.jpg)
![handrail 1.jpg handrail 1.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/104/104292-handrail-1.jpg)
Any thoughts?
Thanks, Doug
