Finally purchased a drum sander, but its a bit smashed up (need parts)
julianf
10 Nov 2017
devon
Its one of these -
https://www.axminstertools.com/axminster-trade-at635ds-dual-drum-sander-106004
(but with a slightly different base)
Anyway, the first bit that i know is broken is the control box cover. The electronics all work, but they're showing their guts to any fingers that can get in.
The axminster parts manual just lists the whole control until, which id probably have to reportage the house for!
Does anyone know if they (axminster) will supply parts in smaller breakdowns of their parts diagrams, or even if one of the other sellers of the same machine might be able to?
Also, I have one (single) sheet of manky sand paper. Im assuming i should carefully remove this, to use as a template, to cut normal sandpaper into "special" sandpaper?
More questions tomorrow when i get the parts together into one place again.
Thank you.
