Hi all
First post and I'm coming begging!
I have an Elu MFF81 planer and the main bearings are now mostly filings. It's a nice clean machine, I've had it from new and it's only seen medium service, so I think it's worth having a go at repairing it.
I saw a similar thread here:
https://www.ukworkshop.co.uk/threads/replacing-bearings-on-an-old-elu-mff80-electric-planer.135385/If simonharper is still on the forum, I would be grateful for his wisdom!
Problem 1: I'm not a mechanic and I don't know how to get the pulley off the armature shaft. Presumably it's a clockwise turn (the shaft appears to be threaded rather than a locknut), and I've tried putting grips on it. I'm scared of damaging the teeth if I start bashing it. Is there a right way of removing the pulley so I can get to the bearing underneath?
Problem 2: Black and Decker say that one particular bearing is no longer available as a spare (I can get the other 3 no prob). Does anyone know what it is and where else to go look? simonharper mentions he changed his with SKF bearings, but until I get that pulley off, I don't know what that bearing is!
I would be grateful for any help here!
Andrew
Andrew
