Dual router fences
LuptonM
2 Sep 2010
Callington
Anyone know if I can put 2 router fences on my Bosch POF 1400 ace at a time, so I can sandwich the wood between them to make it silly person proof?
dont see why not, but if u want the perfect center between 2 edges there is a good jig for that
adidat
A problem you may encounter when adding a second fence is that the rods on the supplied fence are just not long enough to clamp-on a second fence and get a useful separation between the two fence faces. The Trend fence with fine adjustment (to which Hudson Carpentry linked in the third post) is quite chunky, and the fine-adjustment mechanism itself eats up quite a bit of rod length.
Maybe another reason to make your own.
PS LuptonM: I think you'll find that the spare part you linked to in your previous post is just like the fence assembly supplied with the router - the bent-metal fence piece is fixed to the rod ends via screws into threaded holes in the ends of the rods.
Hi,
All you need is a couple of rods and some wood.
How exactly does the wood clamp onto the rods and what parts will I need for this (ie the names so I can order some)?
Looking at the photo I would say that the clamping mechanism consist of two pieces of ply one above and one below the rail. Each piece has a half round groove slightly shallower* than the radius of the rail router into it. The two pieces are then clamped together and drilled at 6mm in order to accept a bolt. The bottom of the bottom piece is drilled out and has a 6mm bolt epoxied in place e.g. the bolt passes up through the bottom and top pieces and the thread sticks out the top. A bristol lever http://www.workshopessentials.com/shop/index.php?route=product/product&product_id=62 is fitted for tightening.
That's how I'd do it anyway :D
* The groove has to be slightly shallower than the radius of the rail or it won't grip. A V-groove would also work fine.
Hi,
Nearly right! the holes where drilled than the ply cut in half for the smaller ones the bigger one I clamped the ply together drilled then plained a layer or two off.
Carriage bolts and bristol leavers for clamping or you can use T-nuts and bolts.
The bar/tube came from B&Q the bolts from Wilcos.
