No doubt you've experienced this yourselves.. visitors happen.. cast praising verbage over a completed project and ask "could you build one similar to that for me??"..
project in question is a coffee / storage table lurking in the living room...
umm.... how similar...??
maybe a wee bit shorter.. a wee bit narrower... no drawers (as opposed to 20), and cupboard doors just on one side???? Que Mk1 eyelash flutter and semi persuasive smile...
Like an eejit I agreed to this..
Anyway... months later I've started roughing out the stock to build the damn thing; plan is to make 3 sides using frame and panel construction... and there's the dilemma.. how best to join the 3 sides together??
The over-riding rule for this thing is to keep the weight down which means a totally different construction method to the original... I need to keep this one real lightweight cos it needs to be humped up 4 flights o stairs. Last time I tried something like this, the project was a blanket chest.. panels connected to each other by mitering the outer edges of each panel (long grain mitres).. Result was a nice tidy looking joint but the glue up was an absolute bear...
Using corner posts with M&T construction would be a whole lot simpler, but the design of the front of the thing won't work with corner posts... Try as I might I can't quite picture the obvious solution... Any suggestions...??
