Clear coat lacquer with Earlex HVLP 4000
sammy.se
3 Aug 2014
London
Hi,
I'm completely new to spraying and I have got myself an Earlex HVLP 4000 to start experimenting with.
I want to experiment with a clear coat lacquer, to go over a simple project I have that has been dyed.
I've tried to read up on the subject, but there is a myriad of products out there, and I'm not sure what I should get.
I want to achieve a satin finish - is that something like 50% gloss?
I would prefer water based, but if the advice is that oil based is better, I'll go with that.
I think I need to put a couple of coats of sanding sealer on my project before I spray - is that correct?
Which clear lacquer and thinner do you recommend I buy?
Many thanks - sorry for the beginner questions!
Sammy
Morrells defines 'gloss' as:
"Term used to describe the visual or measured ‘sheen’ of a lacquer or finish. Typically rated as gloss (80-90%), Satin (45-65%), Semi-Matt (20-40%), Matt (10-20%) and Dead Matt (0-5%). The level of sheen is measured by a gloss meter which calculates the amount of light reflected from the film surface at 60°."
So your suggestion of 50% gloss fits in with their definition of satin.
FWIW, I used Morrells w/b lacquer 30% sheen (product code: 8303/362) on a hardwood floor and, imo, it's a satin finish - when compared to other satin paint finishes - so there's an element of subjectivity here.
It's not designed for floors but having applied by spray and roller/brush I can speak positively about it's ease of application and, so far, performance.
Not sure whereabouts in London you are but if it's anywhere near KT4, pop me a PM and you'd be welcome to inspect the lacquer finish and even pick up for free some 2+ litres of lacquer that I have left over.
Hi Mike,
Thanks for the info and link. Does Morrells sell straight to the public (hobbyist) like me? or just to the trade?
Also - am I right in saying I need to apply this over a couple of coats of sanding sealer?
Many thanks for the kind offer - I'm right at the opposite end of London to you (North East) so it's a little tricky to get to you - but thanks again!!
And am I right in assuming this can be thinned using water - since it's water based?
Yes, it sells to public (like me) but is designed for the trade. This does mean that you're normally looking at min. 5 litres - which may be too much for your needs? I found it best just to speak to your nearerst outlet and pay cash, rather than open an account.
I used it over paint (Morrells w/b white) and bare wood (maple floor) so no experience of sanding sealer. My amateur opinion would be sealer is optional.
It is w/b so can be thinned with water, though it's ready to use as is (I used a Fuji HVLP with 1.4mm needle) and I think Morrells recommend thinning is limited (none to 2% - in very hot weather, for example). I didn't thin.
Ha, NW versus SW London - not a journey I'd undertake!
I have always used morrels ac laquer and have sprayed it with great success through a HVLP spray gun, and had great results, never using a sanding sealer. although I would say if you would like a satin finish 30% in my opinion is best. Once dry you can alter the sheen levels by using wire wool and waxing.
Great. I just got myself some 40% from morrells. do you guys use the viscosity cup measurements to dilute? Or do you use it neat?
