JanetsBears
After a couple of months of owning my new scroll saw, the pile of used blades sat at the side of it was growing. I've tried a number of different blades while trying to learn how to use my new saw. I'm now starting to realise that I can't remember which blade is which, especially if I've slept since last time I used the saw, so thought it was about time I made some means of storing blades that I'd used. The result is this:
The intention is that I use it purely for storage of used blades, dropping a label in each tube as I add blades, so that when I need a Pegas Number 5 Reverse Skip I can re-use one I've previously got out of the pack of new ones. I may or may not make another to hold just new blades, but that can wait. This one is made from 4mm ply and the pattern for it fitted on a single A4 sheet of paper. It took just over an hour to cut out and it's had no sanding before or after being glued - there's more to life than sanding projects that aren't ever going to leave the side of the scroll saw![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
It's being able to quickly knock up little things like this that now makes me realise that I should have had a scroll saw years ago, but what other useful/practical stuff have you made with your scroll saw?
Chris
![BladeHolderB.jpg BladeHolderB.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/41/41916-BladeHolderB.jpg)
Chris
