kingforaday
Hi,
first post here!
I recently purchased a used table saw, basically to try and see how I got on with one, before splashing any serious cash on something better.
I've yet to actually switch it on though, because the seller also chucked in a band saw - which he said "doesn't work but I know what the issue is, the wires to the switch needed taking off, contacts cleaned then put it back on" - now I know this sounds too good to be true and as soon as he started talking I was thinking "the motor's blown" but I do love tinkering around and trying to repair things, so I took it.
I tried as he suggested but, predictably, no joy. looked online and found this forum and some similar issues but none quite the same. So i thought it's probably best to just ask!
The saw is a Dewalt DW738
I plug it in and literally nothing happens, put safety key in, push green button, nothing.
I've tried;
- Fuse in the plug.
- checking continuity with a multimeter and as far as I can tell everything is hooked up correctly to and from the switch.
- opened the main section of the saw (out of curiosity more than anything) and slackened the blade and moved the wheels around, just generally inspected it, other than a load of sawdust inside that i cleaned out, it's in pretty good shape.
Only other things I can think of are replace the capacitor and/or attempt to bypass the switch to see if it's that
From what I've read online so far i'm still none the wiser... if anyone has any suggestions of likely issues, please let me know
first post here!
I've tried;
- Fuse in the plug.
