Anyone with a CNC router fancy a small job on some acrylic?
flanajb
UKW Supporter
11 Mar 2009
Hi,
I have some 3mm acrylic that I need machining. Each disc basically requires 12 holes routed to a depth of 1.5mm.
I have tried and spoiled 5 discs already using the router. I nearly get there, but end up with one of the holes having very small chips. I am fussy, but they need to be 100% spot on.
SO I thought I would see if a cnc router with a proper cutter will do the job correctly.
If you have one and fancy a small job please pm me and we can discuss further.
THanks
Justin
I'm not sure you can accurately etch with a laser...
You could cut all the way through one layer of 1mm acrylic and glue it to a complete 2mm layer. There are optically clear solvent glues.
Justin
Would a milling machine be better? It won't rotate as fast as a router and will be able to perform accurate cuts to depth. Perhaps try a local machine shop?
Duncan
How big and the discs and holes?
If laser engraved isn't a smooth enough finish maybe laser the holes then router the centers so you avoid the edge chipping.
