Any users of CBN sharpening wheels?
graduate_owner
5 Aug 2012
Llandeilo
Any opinions on these? Axminster sell 8" wheels for £100. Looks tempting. Would mainly be used for wood turning tools.
Also, are they suitable for sharpening my older carbon steel turning tools?
K
Those who use them speak very highly of them, one property in particular singled out for praise is their ability to grind fast with much less risk of overheating. I don't know if they're all made equally but this would make one, if it runs as advertised, very suited to older turning tools not made of HSS.
CBN wheels are amazing. I would never go back to using a traditional grinding wheel !
IMHO the 180 grit isn't fine enough. It shows up every striation across the bevel.
I had a job fitting mine onto the 1-1/4" bushes that come with the Axminster slow grinder.
Axminster's response was that the bore is 32mm even though it's stated as 1-1/4" on their web page.
Luckily the bushes run true in a woodturning chuck so some fine emery solved my problem.
You would probably get a better response if this was posted in the woodturning section. :)
Hi Robbo. What do you use to grind your tools, apart from the cbn wheel? What I am wondering is how does the 180 cbn compare in coarseness to alum oxide wheels.
K
