• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Wanted 10 ton hydraulic press
Chris152
26 Apr 2017
Cardiff
Bench mounted, preferably one of the Clarke Strong Arm ones in good condition. It needs to be in fairly easy striking distance of South Wales.
Thanks, Chris
if u have a pillar drill they are so easy n cheap to make......esp a bench mounted one....
u really dont need a welder........apart from the jack which is about £30 from ebay, new....all the metal could come from a scrap yard for just a few quid...
mine's a bit special, as I need to get a 6 cylinder tractor engine on it so that I can press out seized pistons and liners.....
the head moves and has a 25ton Tangye industrial hyd jack.....
this should give u a few ideas.....apart from the winch everything uses 20mm bolts but u'll only need 16mm........
I used 4 car bonnet springs to return the pump ram....
Ps that king pin took a full 25 tons and heat to shift it.....lol.......
